You’d have to really put the heat to it for the bearings to cook. I highly advise you get the side shims to fit perfectly, it might not be a straight drop in situation. I had one that had tight side shims and it didn’t function properly when assembled. The steering was very hard to turn.
If you do tack weld with a MIG, make sure to cover everything to prevent splatter ruining the smooth surfaces.
