I can't imagine the HORRORS of dealing with ROAD SALT, I've worked on a few cars from back there & it's SO SAD.
Bill W.
Anybody hear about the Vintage Rural Tip on how to stop neighborhood male dogs from hiking up their legs at Model A wheels?
Chief was an ARTIST at settin' cotter keys, like what you said, & he would grasp that short end with the dikes & lever the head of the key, TIGHT, in the slot, before bending it over. His Rule was that the key should NOT even WOBBLE! On clevis pins, he'd do it in the same manner & bend it tight OVER the end of the pin & clip it SHORT & neat. That's NOT the high points way, but it's QUICK, EASY & looks NEATanother tip, when your finished repacking the front wheel bearings and reinstalling the cotter key, put it in the hole with the short leg facing out, then cut off the long leg up against the nut, then bend over the short leg, all the cotter key does is stop the nut from unscrewing and the key from falling out, don't need two bent legs to stop that, and its a lot easier to remove the key with only one bent cotter key leg
