Schrader tire gauge repair
Redbird
Has anyone taken one of these gauges apart? I can unscrew the head and that is about it.
Mine was frozen with rust so I left it in diesel for a couple of months. Finally managed to dismantle it, but don't have the spare parts to repair it.
Mine is like the upper one in Redbirds post. The sliding scale is free but it didn't work so I decided to try to replace the gasket material where it contacts the tire Schrader valve. I dug the old stuff out and it was more like a fiber material than rubber. I cleaned it up down to bare metal and there are two metal washers at the bottom. One of them is sort of a flat cup shaped washer which I assume the gasket sits in. I tried O-rings with no luck so I punched out a 1/8 inch thick rubber washer of a diameter which fills the area and I then punched a hole in the center which fits around the post. Now when I put it on a tire Schrader valve it only slightly moves the gage out. Has anybody rebuilt one of these?
Thanks for the info so far. After you unscrew the head there is a disc of some sort with a hole in the center. Anyone get that disc out w/o destroying it. I can give both a hard shake, like shaking down a thermometer, and the indicator comes out. I don't know what kind of spring, as Bill indicated, would be in there.
I just cut a slice mark on the disc and got it out, and a piece of a round gasket. down the center is a rubber liner of some sort that came apart from age. A camera shot down the middle still shows part of the liner. I think I can see a frozen/rusted up spring. I am going to soak in Evaporust over night and see what else I can take out.
I didn't want to mess with that disc since I didn't think I would be able to replace it but I'm thinking my problem might be under there also. A rebuild kit for these would be the answer but for a low dollar item I don't think that's gonna happen.
I got it apart! After soaking overnight, the order of disassembly is: unscrew the head, remove the disc with the hole in it (had to cut a slice in it w/ razor knife), with a large screwdriver back out the spring assembly, remove the "scale" cylinder. The spring was very rusty, so back into the EvapoRust.
Both ends attached to the spring unscrew. There is a thin rubber membrane capped at one end, and open toward the nozzle head. I used the end of a pencil to push it out. It was a little rotted and broke. The spring is back soaking since a few of the windings on the spring were rusted together.
Great pictures Redbird. Now I can see how the thing works. Do you have any ideas on what you might use to replace that membrane?
I got them both to work, by cutting out a disc from carb gasket material, and cut off a finger from a sterile medical glove to use as the membrane. Work very slowly while disassembling and reassembling.
