running warm
frank long island
i'm at my wits end :mad: replaced radiator removed thermostat added a shroud still running warm :eek: would the timing cause this condition did'nt do this till i messed with the timing
i belive it was bumped up by the mechanic i had changed the distributor and set it by ear to get it to him ran good :) it was changed to a 62 p/u dist. also the carb was changed to an edelbrock 1406 small 4 bbl
If memory serves me correctly overly advanced timing can cause it to run warm and if that new carb is running lean it will also.
Is the therostat still out? That will cause the water to go through the rad too fast and not get a chance to get the heat out. Put in a 180* thermostat.
First question, what is warm? The gauge pegged or actual temp? Stock gauges are notorously incorrect as far as temp so get an actual reading if you don't have one. Don't rely on just the stock gauge reading. Might want to invest in this and check actual reading http://www.grainger.com/Grainger/ww...uery=5Xl18&op=search&Ntt=5Xl18&N=0&sst=subset. If this does not work, go to the web site and put in 5XL18 in search
185 to 190 is not bad. Old saying - If it doesn't boil over, its not too hot.
thanks to all i retarded the timing and adjusted the carb and it seems to be better now running between the 1/2 and 3/4 marks :D although when idieling it moves to the hot side have to see what the a/c running brings:confused:
thanks to all i retarded the timing and adjusted the carb and it seems to be better now running between the 1/2 and 3/4 marks :D although when idieling it moves to the hot side have to see what the a/c running brings:confused:[/QUOTE
If you are interested in finding out just what the temparture is, get a meat thermometer, run the car till it reaches normal operating temp, remove radiator cap (be careful here) and stick the thermometer in. it will tell you almost immediately what the temp is. You can also do this by shutting off the engine when it reaches normal operating temp (again be careful) and put the thermometer in. Remember, once the engine is shut off, the temp will climb by 10-15 degrees from operating temp.
Or you can get a infared unit, and just point it at the engine, rad, or whatever part you want to get the temp.
