frank long island
i'm at my wits end
replaced radiator removed thermostat added a shroud still running warm
would the timing cause this condition did'nt do this till i messed with the timing
i'm at my wits endreplaced radiator removed thermostat added a shroud still running warm
thanks to all i retarded the timing and adjusted the carb and it seems to be better now running between the 1/2 and 3/4 marksalthough when idieling it moves to the hot side have to see what the a/c running brings
[/QUOTE
If you are interested in finding out just what the temparture is, get a meat thermometer, run the car till it reaches normal operating temp, remove radiator cap (be careful here) and stick the thermometer in. it will tell you almost immediately what the temp is. You can also do this by shutting off the engine when it reaches normal operating temp (again be careful) and put the thermometer in. Remember, once the engine is shut off, the temp will climb by 10-15 degrees from operating temp.
