Paul Howes
the gap between the rotor cap and the distributor cap is about .036 instead of .025. How can I adjust the gap to make it smaller?
Bend rotorthe gap between the rotor cap and the distributor cap is about .036 instead of .025. How can I adjust the gap to make it smaller?
Be careful if you try and bend the rotor tab. I broke the re-pro rotor doing so once. I think the re-pros are plastic, maybe different than an old rotor, maybe Bakelite(?). The solder-on tab makes sense.
Are you having issues ? .036 shouldn’t be a big issue, in fact it may give you a hotter spark , some here will disagree BUT do an Internet search for spark intensifiers , that will back me up
Where did the .025 gap specification come from??
