hardtimes
Regarding the lower '30 roadster stanchion: I've two questions on two problems that I've encountered.
First, is it possible to replace the threaded worn stud in the lower stanchion...the stud that holds the lower/upper stanchions together?
Next, the lower stanchion is fastened to the body horn by two screws. If the screw hole threads are worn, where new screws can wobble when put in..is there a fix for this?
