I'm replacing the front motor mount springs on a 1930 Tudor as the current springs are after market with rubber inserts. Hand crank does not align properly.
After I loosen the rear mounts, what is best way to raise front of engine to replace these springs? Is a 2X4 with jack under the oil pan OK...or is there a better way. I don't have access to an engine lift.
Thanks.
Thanks.
