My3window
Following the many posts on Ford Barn I was successful in unclogging the small tube running from the top of the gauge to the lower reservoir. I am preparing to add the hydrostatic red fluid back in the reservoir but before I do I would like recommendations on the best sealant to use when reconnecting the air line nut to the top of the reservoir. In the past I used teflon tape, but I noticed when I poured metal prep first and than lacquer thinner to unclog the line that both liquids turned milky during the process in the glass tube. Could this be from the white teflon tape? Is there a better way to seal the air line tube to the reservoir once the red fluid has been added? Thanks for any advice.
