Werner
Hallo Ranchero,
are you sure that the correct screw length has been installed? The rubber intermediate layers must not be squeezed because then the springy comfort cannot swing.
The 3 sleeves should prevent too much compression.
The required tightening force was very low, I estimate the torque at 2 m / kp.
The other picture shows the protruding screw ends and the soft rubber plate in more details. -
At Katy: You are sure to be on the right place?
