Tom's36coupe
Have the steering wheel, column out and wondering what the secrete is to get the hub and wheel off. Thanks!
Tom-
Several ways to do it but the simplest way is: 1) remove horn rod assembly and wheel nut; 2) slide column down leaving a gap between the wheel and column; 3) mount bearing separator; 4) use a gear puller to lift off the wheel
Tom
