Remove inner panel
Bill in SoCal
I am trying to remove the inner panel from a rumble trunk of a 30 coupe to repair some rust through on the rumble set riser (see picture). I can get behind all the slotted screws except the six on the top of the panel (see picture). Are d-nuts used behind these six screws? If not how do you reach these nuts? Does another inner piece need to be removed with the inner panel?
i just removed a bunch of screws just like these this weekend
i used my torch with a small tip
heated just the head red hot,it took a couple of cycles of hot and cold,and every one came out without any breaking
