flathead4rd
I'm getting ready to reinstall my 8BA engine. I thought that since I had it out, it would be a good idea to replace the old motor mounts and radiator hoses. Any suggestions as to a procedure to use? I was going to install the motor mounts on the water pumps first but leave them slightly loose for some wiggle room. Next lower the engine to align the mount studs with the front cross member holes. Any other suggestions welcome especially about the lower radiator hoses. The radiator is not in at this time.
