Guys thank you for the suggestions and the encouragement it really helps. I was depressed as hell when this thing wouldn't fire but considering all I/We are finding wrong with it I am most thankful it didn't!
Just so we are all singing the same song, I will pull the pan. I will see if I can get the crank gear off and either turn it or replace it and reset the cam timing correctly. While I am looking at the lower end I will check to see if there are areas I need to be concerned about. While I am doing that I will pull the heads and pull the valves and do whatever I need to do to use the valves I have. The seats are new, the valves are new, the lifters are new, the guides are new, the springs are from a 1950's 8ba. May or may not have been original to that engine. I may have other used ones in my stash but these looked to be the best of what I had. I'll do whatever needs to be done to correct their geometry and put them back into the same cylinders they came out of and relap them. I will use all new gaskets and reassemble it. Sound like a plan? Have I missed anything?
Only problem is all of this has to wait until after my trip.
