Bassman/NZ
I wouldn't do a thing to that engine until you have read JWL's Flathead Facts book. It will save you a bunch of unnecessary spending. Even if you have no other, that is the one book every flathead owner should have.
I would not trust a sixty year old oil pump, checked or not, with a lot of new parts..
Would this hold true for the fuel pump as well?
Fuel pumps are a lot easier to change than oil pumps so they are not as critical. Also understand duel carburetors may need an electric fuel pump to boost the flow. Personally I use electric pumps. If you replace the mechanical pump don't forget to plug the push rod hole.Would this hold true for the fuel pump as well?
