got the adjustable lifters in, cam back in ,timing gear and crank lined dot to dot,put cover on and pin in till tdc #1 now the question how do i line up the pump shaft and gear and dist in the right order, best i can figure i lined the oil pump shaft slot to the nub that goes up in the block then figured out where #1 was on the cap lined then lined gear so slot from the dist would slide in keping #1 lined then reinstalled oil pump ,not sure if this is right ,but want to get it right because waiting on new mallory dist from bubba gmc to install any help would be great,did call a few older guys near me ,but the response was go buy a book to learn it.they didnt seem to get that i understand how this stuff works just want to make sure i am putting it back right
