barnnone51
Been having a lot of oil coming out the clutch housing bottom. Checked the tube not clogged. Also clearance was 15.This is the second time trying to fix
this problem. Removed the motor out this time. I did find this piece that was loose. lt looks like a piece that was added. With this loose could that be the problem? If so what would be the fix? Any help would be appreciated. Thanks
