rear brake drum puller
I always say if a hub comes off with a puller other than the ones mentioned, it wasn't tight enough!
I would be interested in one , No i do not have the box . If you are interested in selling one give me a call. Thanks Stan 775 364 4367 Northern Nevada
Sorry super busy. Message message through barn is best for me. $200 plus shipping. Cheers
Is this correct for 36? It doesn’t fit on my 37. Bought it years ago for a 36 but never used it.
Rock, that’s what I thought when I bought my puller but it doesn’t fit my 37.
The Vintage Precision will, I've pulled my 32 Ford & 39 Mercury with it!!! Works swimmingly, Fixing to use it on my 47 Mercury here shortly!!!..... AS advertised "28-48"
Tim
Here is a photo from vintage precision's web page, as you can see, the cap that screws onto the axle end and you push against, has a long slot that it can slide in for short OR long snout hubs!!!!! As it states, it will pull from Model A's to 48 V8's!!!!
Tim
504768
Tim
I had a little project to finish up in my shop so sorry on the delay in getting these posted, I hope this is what you were asking for???
I had that problem on my 38 too. I called them and they recommended sanding off some of the surface roughness on the ring. Worked like a charm.
