raven rivet setting trick?
I use a scratch awl to poke a hole in the lacing for the rivets, then use a thin flat screwdriver to start the spread. Use a plier to finish the spread. You can modify one plier jaw by using a Dremel to give the rivet legs a nice curl as original.
http://www.frankstpartsltd.com/default_files/Page497.htm
Has a tool
