Radiator shroud emblem removal
Smooth_One
Stupid question but how do I remove the emblem on the shroud?
I want to try and keep it intact and re-install after I clean it up.
Just tap it from the back.
You might want to put some oil on it before hand and let it sit. Looks rusty.
Light tap putting the handle end of a large screw driver against emblem.
Replacements are not as good.
Enjoy.
Enjoy.
Thanks so much! I thought it unscrewed somehow.
What would you guys recommend if the emblem is too loose a fit in the radiator? It there a way to flare out the ring on the back of the emblem a little? Or maybe just a little silicone?
