What is a quick fix for a drip where the hose meets the pipe . The clamps are tightened all the way down. Thanks John
H.L,Cast iron water outlets are very porous when compared to solid steel tubes used for metal fuel lines.
Quite a few post in the past were presented complaining about very tiny coolant trickles & very minor coolant leaks over several weeks causing a few coolant drops on the garage floor ....... which incidentally can accidently poison one's pets.
The dielectric grease in reply no. 8 above can seal porous cast iron like oil seals a cast iron skillet which creates a non-stick sealed smooth surface ......... but not many know anything about how to condition a cast iron pots ......... or how to clean cast iron pots with salt ........ or even how to use a chamber pot ...... then ......... if one cannot use a simple pot how can one figure out how to control leaks?
H.L,
I don't know if this applies to CAR parts or not, but old abandoned cast iron cookwear can be "restored" in an oven, on the CLEAN CYCLE!
But some folks are so poor, they don't have a POT to P** in, or a window to throw it out of!
Bill W.
Hi Bill,
And, at the rate we are going to pot, seems pot will soon be available in all 50 States.
Then we can acquire a new saying:
"Folks are so poor they don't have pot to smoke, or the cigarette paper to roll it in."
And then ......... nobody will care whether their Model A radiator hoses leak or not.
H.L, you could probly make this into a POEMHi Bill,
