ctlikon0712
After I cleaned my system with pool strength Muriatic Acid %20 and water %80, I rinsed several times till the flush was clear. Then I mixed a solution of Phosphoric acid and water (ospho) 10-20% and DI water and let it set over night to treat the block. I then drained that and used DI water and a common rust inhibiter/antifreeze mix and my coolant has stayed clear, minus the WP lube......
