Jim in Upstate NY
How hard is it to change out a stock 37 thru 40 rearend center section to v8 quickchange. Both are closed drive. Thanks, Jim
I wouldn't think you would have to change the drive shaft length. What kind of quickiechange are you considering? Wayno
The spider carrier also needs to be machined to clear the lower shaft, the pinion gear needs to be machined to fit into the rear cover bearing.
make sure you get a set of ear plugs.every one i ever rode in cryed like a spoiled brat in a toy store.may be the new ones are different i am sure the barn will chime in
I've got stereo. An old Halibrand V8 QC in the back, and a GMC 671 up front on the Flathead. No ear plugs!
