Kevinsrodshop
Just a quick question about the clevis and pins at each wheel for the mechanical brakes. I assume they should be tight and have no slop in them. Mine are quite sloppy proabably from the 80 years of use. By the time all the slack gets taken up the pedal has moved quite far and hasn't even started engaging the brakes yet.
lso I've put on new linings and retracted the adjusters as much as I can. The drums fit but there is some drag on the new linings that, I'm sure would wear off quite quickly, but is this normal?
