40cpe
If you used the Ignitor I unit and a coil with at least 1.5 ohms between the two screw terminals, you don't need a resistor. You can use a resistor, but Pertronix told me that it might give less performance at higher RPMs, something most of us flathead owners needn't worry about. The upscale Pertronix units can use coils with less resistance. So, which pertronix and coil you have will determine your need for a resistor.
