Due to a recent breakdown I ended up dropping the rearend to determine cause, which turned out to be the U joint. In the process, although still in working condition but showing signs of wear and a rather noisy second gear, seems like a good time to rebuild the trans. Be advised, the bolts holding the bell housing to trans are wired inside so I had to remove them as a unit.
