Art Newland
Just my own thoughts, but I certainly wouldn't be running MY engine without coolant of some sort, even for a short while.
Was full of water.
I used an infrared thermometer and let it run until it hit 160-165 F.
Art, I bet you had a smile a mile wide when it fired and ran.
I noticed that you don't have a clutch fitted. Normally, the final balance of the crankshaft is done with flywheel and pressure plate fitted. What are your plans here?
with 42 of your own posts on this thread you had time to rebuild the engine yourself ( lol ) ! Wayne
For those of us without a lot of spare A parts, and that don't anticipate needing to test several A engines, I've used hose couplings to the inlet and outlet and run water in from a hose bib. The thermostat keeps the engine at operating temp for longer tests. On an A with no stat, you can regulate the water flow to do the same.
Here's an aluminum 215 Buick I did this way recently...
https://www.youtube.com/watch?v=5jBGMO50Kjc
With alll due respect your not going to keep the block and head / heads full and prevent hot spots internally with a 5/8th garden hose using house pressure...
this is my last comment on this
Art your motor sounds great on the video enjoy
That flywheel cover and flywheel won't go in the car, I'll use the ones that are in the car now, although I have to admit that the one on the test engine looks really good, no heat checking that I can see. I have a new clutch and pressure plate to go in as well. My plan is to run all that on the stand, I'll play with "clocking" the flywheel and pressure plate to get the smoothest run.
What can I say, I'm a shade tree mechanic!Maybe I'll find an old usable radiator some day, wouldn't be tough to weld up a bracket, if you look at the front of my engine stand, you'll see some metal on the front, that was put there just for that possibility. Would be fun to have it setup with a generator on it as well. I try to seek out good information, but in the end I really like to see for myself. I really like for folks to see that if they wanted to do some of this kind of work, it's possible.
So neither the flywheel not the pressure plate will be balanced on the crank when it goes into a car? You might get lucky.
As for JB weld over that hole in the head, I imagine standard heads are very cheap over there and plentiful. I'd go that way or as you say, a new 5.5 head. A friend of mine over here had a crack in the water jacket of his motor. He soldered it up with ordinary 50/50 lead/tin solder. The trick was getting the cast iron tinned.
And then when ur done with it return it![]()
You could easily set up a modern plastic radiator to it .. they cost around 89.00 new
Like wearing the dress to the prom and then returning it on Monday morning?![]()
