PS idler arm
I see that you have the idle-arm bracket and the other half of the bushing that came out of it laying on the garage floor (picture upside down).
Can't say as I have ever seen an assembly like that. I think it would be a big help if you had a '57 Ford car shop manual to see what the factory showed in their illustrations and try to order those parts if available.
I just looked at the latest Mac's catalog and they are not offering the complete kit for '57 Ford with PS. They do offer the metal encased bushings (MA-3358-A & MA-3356-B), but I am sure those won't work with the idler arm you have.
K=thanks for the info on the build date, that may explain the June 14 1957 build date instead of earlier in the model year.
Dave, I was looking at my manual and their pics don't show anything really. just bad pics of the system. I did see some rubber bushings like mine in a catalogue but they are for a non-power steering bracket. So it is possible that someone rebuilt it with non PS bushings at some point in time. Those are the bushings that I bought for this application as they are for the PS idler arm according to Concourse.
Mike
Update. I got the PS components rebuilt and installed. Only to find out there are two issues. Neither of which were really my fault. First I apparently had the bushing installed backwards with the long one in the center link and the short in the bracket. They should be reversed-according to a spare 57 PS set up. I also noticed the idler arm is different from the spare to mine. So my thinking is that they had to replace the idler bushings at one point and couldn’t get a PS set and used a manual set up.
Mike
You are going to have to source a correct idler arm for the car. What you are working with is incorrect.
You are beating yourself to death for no good reason,
One of the two is correct, I just need to figure out which one.
The take-off shown below is not correct. It must be an outside vendor service replacement. You would need the original busing set to make it operable -
I have installed, I just have them in backwards. So I will send it back to the shop to get them reversed and then reinstall.
Mike
Ok, all of the PS components are temp installed now and appear to work as advertised. Now how do I tell which side which long tie rod goes to?
Mike
The info and illustrations on page 4-4 of the '57 shop manual may be helpful.
Rotate the steering box or steering wheel back & forth a few times until you can determine when the movement of the steering box & pitman arm is centered, the middle spoke of the steering wheel should be pointing straight down.
Point the tires & wheels straight ahead and the tie-rod placement may become evident.
