proper 40 PU horn button
Kube
Super Moderator
What does a concourse correct horn button look like for a 40 pickup? I don't mean according to Drake or another supplier. I mean concourse correct...
Thanks.
I'm probably wrong, but this is the one I always associated with the 40 pick up.
Don't know if they are the same, but here is the one that came with my 41
I have a nos one, and the FORD script and border are a beautiful red color that turns to a reddish gold when turned to the light. Repro buttons that I have seen are just painted an orange/red.
Mike, based on my poor ole 40 pickup,a wore out farm truck when I got it, and what I have gathered from other sources, I believe the horn button is of the same style as the standard car, i.e. circular rings and the stylized v8 logo, but in a molded black color to match the steering wheel color. On my truck the color has changed from a pure black to something less, but still very dark and certainly not close to the Briarwood of the car wheel and button. As you can guess, the repo ones sold for 40 commercial cars could not be more wrong. In 41 with the other engine options the v8 logo went away and the button had the ford logo inside a sorta rectangle that mimicked the 41 pickup center dash /hood side logo emblems. The repro s are ok for 41 but not 40. I can send you a pic of my 40 button if you like. The v8 logo is very faint.
This is my observation and giving 40 info to you is like talking 32 stuff with David. So if you think I am wrong, I am sure that would be true. Have fun with your 40 pick up, I love mine.
Just an opinion
Floyd
My original 40 pickup had the V8 as Floyd described. Unfortunately I let that one go many moons ago....
I agree with both you and Floyd. The horn button on my 40 tonner is black with 3 white concentric rings on the outside and the V8 logo in the middle. Its an OEM button that is original to the truck. I can't vouch for it being concourse correct, but in the only judged Ford event that I showed the truck I didn't get a deduction for an incorrect horn button for whatever that's worth.
Les Williams
Thanks.
Mike
This Dennis Carpenter button looks like the one on my tonner except the logo in the center is white and the rings on the edge have traces of white paint in them also. http://dennis-carpenter.com/horn-button/p/01C-3627/
Les Williams
Thanks guys. From my research, I believe Floyd, Expavr and Californiaborn36 have this correct.
Thanks to all...
Thanks to all...
Then what is the Ford in the rectangular box correct for? Since a few of us seem to have some OEM ones I'd like to know.
I think, mind you, I think, they are either 41 - 47 or 41. I am not certain though.
I do know I never count on Drake, etc. to teach what is correct or not. Too often they model their parts after service replacement parts. And, we all know - well, most of us know, that service parts were not necessarily concourse correct.
Too bad Ford did not have the part number embossed into the plastic! The Chassis parts book list the same horn button for the commercials as well as the bigger trucks, 01C-3627. Neither the Commercial or truck owners instructions show the button.
I looked for an official Ford 1940 pickup photo that shows a clear interior shot but could not find one. There is a factory photo of a '42 Army p/u that does show the Ford in rectangle horn button and while not definitive it does add credence to the '41-'47 theory.
The 40 pickup horn button is black with Ford script in the center. The ones sold for years are not correct. Carpenter cast some correctly a few years ago (about $40.00 each).
Do you mean ONLY the Ford script or the script surrounded by a rectangle?
I recall Bob Moon was somehow instrumental in getting Carpenter to make the buttons. However, I do not know what they ended up with.
In absence of evidence to the contrary I think that Dennis Carpenter's label of 40-41 on the V8 logo is the most accurate for judging purposes. The appearance of the rectangular Ford script labeled buttons could have appeared in the 41 model year when Ford ran out of the V8 logo buttons. Of course the other possibility is that Ford management decided to maliciously do a mid year switch in order to provoke a debate at some future point in time.:D
The horn button part number for the ford script in the rectangle is 11C 3627. That tells you the answer. (1941). I believe that was used from 41 to 47. Makes sense since the logo exactly matches the hood and dash emblems that started in 1941 and takes in account the availability of the 6 cylinder engine. The original part number 01C 3627 with the v8 logo (matches the hubcaps) may be lost to history as a one year item. The chassis parts book (green bible) doesn't help matters as it notes the 1941 part 11C for 1940 truck. We know that is because the fit and function for the 1941 part is backward compatible to 1940 even though the logo is different. The vendors are not helping matters as they are using the 1948 version of the green bible which is seldom correct for a specific model year as issued. I am still sticking with my unloved, untouched and never serviced 40 pickup with the black v8 logo horn button. (it looks better know).
just an opinion
Wasn't there also a 4cyl available for 1940? and wouldn't it have been different than the circles and V8???
