Hi,
Can anyone point me in the right direction to find the procedure for assembling a '34 rear axle?
I've got info on the pinion bearing pre-load at 12 to 17 lb in, and that the differential side bearing adjustment should be a 'light drag'.
But what about the other clearances? I've heard mention of 0.050" to 0.010" backlash, but how/where do you measure this? Is this backlash the amount of axial clearance? Do you assemble with a set of gaskets either side of the banjo until there is no backlash and the diff side bearing drag slightly and then move 0.050 to 0.010 of gasket to the left side?
Many Thanks,
Mike
Many Thanks,
Mike
