corvette8n
Did you check to make sure you had a good ground? It may not be any of those items. If you don't have a good ground on a 6 volt system you will get the same symptoms you described in your original post.
+1 on this route, a very good ground is something folks don’t think about, clean tight and bright, I usually add a ground between engine block and frame/body.
