sanborn
As a result of some trading, I ended up with a two carb intake. The carbs are spaced so the generator bolts in the stock location. The carbs are spaced so the original air filter fits the carbs. The carbs face rearward. The intake bolt pattern is an early pattern. The is no identification on the intake.
A friend said he thinks it is a factory interceptor intake. I remember reading in the 50s of a factory two carb intake but have never seen one. Could this be the one?
