keyswitch1
1. Could some body explain this to me ??
2. Do I do this before or after I put the regulator on it ??
doesn't matter which design,exciting the field wire polarizes the generator.
So, do you know anything about the cut out on your car? Is it special $ and a modification or is it a reproduction or original? Don't start testing the generator until you get past the Polarize step. If it is a regular cutout (not diode) you can polarize by jumping with a wire or the handles of a pair of pliers From one Terminal to the other Terminal. There are only 2. Only takes 1/2 second, with wires connected as usual. If it charges when started to the Plus, you're good.
