MrTube
Cleaned up the distributor last night, replaced all worn and nasty looking hardware as well as the bottom plate.
Unfortunately I also found the points like to ride down and hang slightly lower then they should on the ground contract. It looks like the pin that holds the points is tilted and not square to the top plate.
I assume the only repair is to replace the top plate? can I cheat in the mean time with a washer to raise them on the pin some?
Thanks,
Chris J.
Thanks,
Chris J.
