Anteek29
I want to verify the ignition timing on my 272, beginning with the #1 piston at the top of the compression stroke. I've read the term "Piston Stop" so what is the best way to confirm once I pull the spark plug? You guys use a cable tie? Car is manual shift, so I can push/pull in 3rd. to move the crank as needed. TY!
