V ventport Member May 18, 2023 #22 Zerk fittings replaced Alemite fittings on almost all makes by 1934. Alemite is old school for grease fitting.
S santino2010 Member May 18, 2023 #23 Ok got it I'll see if I can get a flat spot there but It doesn't look flat it sort of looks round
S santino2010 Member May 18, 2023 #24 It doesn't look like a flat area on where the grease fitting is
fordor41 Well-known member May 21, 2023 #25 I just checked angles on our '60. I removed the D.S. and found a piece of pipe that just fit the U-joint recess of the pinion yoke, Turned the yoke to the vertical position and that gave me a true vertical surface to place my angle finder
