Curt Cummings
How do I post photos in my adds on Ford Barn. I haven't been able to figure it out???
The problem most people have is trying to post photos that are too large. Set your camera to the lowest resolution possible. Alternatively, use software to reduce the size of the photos. Place your camera card in your computer (or save your photos to your computer). With the correct size photos after you type your text you should be able to go down the page to "Additional Options","Attach Files", "Manage Attachments", "Choose File". Try this and see if it solves your problem.
Charlie Stephens
I simply download my photos to PhotoBucket, without doing anything to them...no re-sizing needed. Then I just click on the photo I want to use, and on the right hand side are several image options.....I use the one labeled "image code"...I click on that, then go to Fordbarn and the reply window, and use "control v" to insert the image...it will not be visible until you hit submit or reply. I use several forums and Photobucket works great on all of them.
I have a Canon 5d camera that is rated at 21.1 megapixels and that is where it is usually set. If I am taking pictures specifically to post I change the resolution in the camera or afterwards with editing software. My concern with hosting sites is that eventually they will change and mess things up or decide to delete photos after a certain period of time. I would like to think the photos added directly to fordbarn will remain as long as the site is is existence.
