johnr9q@yahoo.com
I bought P/N A-7508-Q4. Two bushings are required for each pedal. In the original bushing the hole in the bushing lined up with the Zerk fitting. There was a half moon drilled at the end of the bushing so when they were installed there was a complete hole that aligned up with the zerk fitting. As you can see in the photo the hole in the bushing is in the middle and not aligned with the zerk fitting. I guess the solution would be to drill a new hole thru the zerk fitting into the bushing.
