Hello. I’m wanting to run a valve cover that doesn’t have the oil bypass tube. I have an A block. The block is not full oil pressurized. Will this create a problem not having the bypass tube on?
IMO, If the tube was not necessary, Henry would have saved the $ and not put it there. I suspect that without it, there would be too much oil in the valve chamber and some of it then being sucked up the inlet valve stems and burned.
For a brief time Ford produced Model A engines without the oil return tube but soon went back to installing valve covers with tubes, probably for the very reason cited by Synchro909 above. The later Model B engine had pressure to the mains and the excess leakage into the valve gallery was drained via holes to the dipper tray.
