peewee2you
Does the Oil Sending Unit screw straight into the back of an 59AB Block on a 47 Ford? Or is there an adapter that goes between the black and the unit? Please see photo of my current setup, which has a 45 degree L in the block with a long stem so it's easy to put the wire on the sender.
The problem comes in where I noticed at the block it can not be tightened enough because then the long extension tube would be directly into the firewall.
Thanks
Peter
Thanks
Peter
