flatheadmurre
My experience with an 80# sender and original gauge (35-41) ,the gauge reads 1/2 of what it should be and not the other way.
The meters doesn´t know what they are reading...they are the same for fuel/oil and 50/80lbs.
You need to match up the correct sender for what you need.
As you say 80# sender on an old motor read low and sticking a 80# oil pump into an old car with original sender will read high.
Calibrating the meters takes time...they move slow and just a tiny change of the settings are needed....you really need to have them on a workbench with a known good sender to make it work.
