Fillinjc
Hi,
Ready to install the oil pan on my 1930 coupe. There is a small step (.005-.010") where the front timing cover meets the block due to rope seal pressure. Will be using the Snyder's cork gasket that specifies no sealant. Will the gasket seal this step or should I loosen the timing cover and try to realign?
Thanks,
Jerry
Thanks,
Jerry
