quickchange
Does anyone need the oil pump slash shield as i have a number of them or are they easy to get, Derek from a sunny warm day in NZ
Here is one.Could someone post a picture of the difference in the flange of the windage/oil tray, from the early one for use without the oil pump shield to the later tray for use with the oil pump sheild?
Lowering the level in the sump DOES help with rear main loss. You technically don't need all that oil since if the oil pump inlet is covered, there is no change to the amount or degree of oiling being performed within the engine. I typically run perhaps a inch down from the top mark on the stick..How about lowering the level in the sump? Right now it is just below the full mark. Thanks
need pictures of the side of the oil splash pan,where the bumps that go into the pan are. B is suppose to be lower sitting in the pan. need to see the difference by comparison side to side. thanks steve in tampa
Back to the holes in the dipper trays, 50 something years ago I tour down a 29 engine with 1 inch holes in it that looked like factory made holes. I asked an old man that had lots of model A experience back in the day and he said that the Gleaner combine engines started using trays with holes in them and the larger oil vent pipe for a longer lasting engine. He said that the hot rodders back then started doing the same thing. It was claimed that it let oil down to the bottom of the pan quicker.
