rfitzpatrick
Is an Oil Filter on a stock engine worth the effort/money?
Tks
Tks
IMO yes. Many here disagree on the need if you don't drive your car often. Filters tend to extend the need for oil changes. However, always check your dipstick to see if the oil is getting dark and then you know its time to change. Filters do not cost that much.Is an Oil Filter on a stock engine worth the effort/money?
Tks
On an inserted motor, in my opinion, it's a must. I use a Wix 51068.
I had a 1956 BelAir once, and that stovebolt -6 was built without an oil filter. They buyer opted to skip that option.
I recently swapped in a modernized engine with insert bearings, counterbalanced crank, upgraded cam and 6.5:1 head. To be clear, this is an original block, not a Burtz block.
I asked the builder which kind of oil filter system he recommended but he absolutely refused to install an oil filter at all. He said he’d rebuilt engines destroyed by filter issues, and to just change the oil every 1,000 miles. First time I ever heard this. Anyone have first hand negative experience like this?
Stock pumps are made to flow a lot of volume but may not have a lot of pressure. I think the rebuilders who don't like added filters are speaking against this system (just my opinion). This system can reduce the flow of oil to the engine because it is adding resistance to the flow.
