Werner
For those of you running a by-pass (partial flow) filter, what type of filter is being used? A proper by-pass filter or using a full flow filter plumbed in as a by-pass filter?
Kathy,
I think it doesn't matter whether a filter is in the direct flow or bypass flow line.
What's important is a low resistance to pressure pump, a pressure relief valve in case it ever gets clogged or a cold thick oil has to be pumped through.
I personally opted for a short screw-on filter (f. e. "MANN W 77") so that the style break isn't too noticeable. Painted engine green.
There's a temperature measuring strip stuck to the outside. In the cold season I put my wool sock around it so that the oil doesn't stay too cold
