Oil capacity
Brianfrench65
Well...I've added a temperature gage, put in a Nu-Rex upper plate with modern points, new distributor cam from Brattons, new plugs, changed the coolant, and changed the oil.
When I put in 4) quarts, I read "F" on the dip stick. I looked in the book and it calls for 5) quarts.
What is the correct answer?
I don't want to overfill it, and cause more problems.
5 quarts fills an empty oil pan. When you drain it after that 1 quart stays in the dipper tray and you put 4 quarts in after that when you change oil.
