Wayne Schuenke
I have a 50 ford 6 cyl with overdrive on the relay on the fire wall should I have 6 volt on all three contacts looking at the relay the upper left above the fuse goes to the ignition switch the bottom right goes to the OD solenoid #6 it has no juice going to it should there be or does it get juice after 27 mph
