jaguar6165
Is it normal for the engine stud in the center of the driver side to have a sleeve around it? I am in the processes of removing the old studs to install new ones with a new head. Just have a few that don't want to go.
Someone used a sleeve to replace the thickness of the distributor cable clamp, which they didn't want to clamp to the head stud.
Be patient with those few that don't want to go. Either leave them in or search this site for tips on removing them. If you break them off you will really wish you left them in.
I would just venture a guess that the corresponding hole in the head is waaaaaay oversize and the sleeve is there to make up the difference. If it were mine, a new head and set of studs would be on the way.
I bought a 5.5 head buy haven't installed it yet.
Also, what's up with the starter end plate? It appears to be bent or loose due to the gap showing in the picture. I've seen people try to mix and match wrong end plates before, and it usually results in a mess. Some have slots and pins to locate the plate, and others have an upset and notch.
Is the hole in the head a bigger bore for that one stud? It loos like it would have to be. I have a block with studs that are larger on the block threads but the same dia. as the standard studs through the head, kind of a step stud.
