CWPASADENA
If the chirp starts just as the clutch starts to engage it is probably the pilot bearing squaking, if the chirp happens after the clutch is engaged and just as you take your foot off the pedal I would look toward the throughout bearing as the cause
I agree;
I am thinking more along the line of a dry Pilot Bearing. If you get the trans out, be sure to look at the Pilot Bearing along with the T.O. Bearing.
Chris.
