HoarseWhisperer
Background: Had a shop take out gas tank for repair in which they had to remove the distributor, etc.
Symptoms:
1. No voltage to points.
2. Ammeter shows -8 discharge turning ignition switch to ON.
3. No spark from High Tension coil wire.
It will turn over and I have 6 volts at battery, starter connection, junction terminals, coil terminals, etc.
Can I assume since the ammeter shows discharge turning ignition on, that the ignition cable is ok, but have a short elsewhere? I already loosened the cable to distributor a turn thinking it might be grounding out.
Based on the symptoms, any guidance on how to isolate the cause?
Did I mention I'm electrically challenged with a multi-meter, but I'm trying?
Symptoms:
